HEALTHADVISORTASKS system variable
Health advisor tasks
Select which drawing health tasks to run in the background. Valid only if the health advisor is enabled (HEALTHADVISOR system variable is ON).
BricsCAD only
| Type: |
Short |
| Saved in: |
Preference |
| Range: |
0 to 127 |
| Default value: |
14 |
| Possible options: |
1: Purge 2: Audit 4: DmAudit 8: Overkill - duplicate geometry 16: Overkill - duplicate blocks 32: Blockify - match existing blocks 64: Blockify - equal solids |
