HIDEPRECISION system variable
Hide and shade precision
Controls the accuracy of hides and shades. If on, uses double precision, more memory is needed, which might affect performance.
Type:
Short
Saved in:
Not saved
Default value:
Off
Possible values:
Off (0): Disable double precision
On (1): Enable double precision
Related commands
  • -VISUALSTYLES command
  • SHADE command
  • -SHADEMODE command
  • SHADEMODE command
