HIGHLIGHT_ALPHA system variable
Highlighted area transparency
Controls the transparency of a filled area when selected.
Values between 0 and 100 are accepted. A value of zero means fully transparent. A value of 100 means fully opaque.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
0 to 100
Default value:
85
Related variables
  • HIGHLIGHT system variable
  • HIGHLIGHTCOLOR system variable
  • HIGHLIGHTEFFECT system variable
