HIGHLIGHTCOLOR system variable
Selection Highlight Color
Controls the highlight color used when GLSelectionHighlightStyle is set to Use a different color for highlight.
Note: The HIGHLIGHTCOLOR system variable is effective only in the 2dWireframe visual style.
BricsCAD only
| Type: | Short |
| Saved in: | Registry |
| Range: |
1 to 255 |
| Default value: |
150 |
