HLRNEXTGEN system variable
Next generation hidden line removal
Speed up parallel hidden line removal by using an experimental next generation algorithm.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
Off |
| Possible values: |
Off (0): Don’t use next generation algorithm to speed up hidden line removal On (1): Use next generation algorithm to speed up hidden line removal (Experimental) |
