HPGAPTOL system variable
Hatch pattern gap tolerance
Controls the tolerance for a boundary created with the BHATCH or BOUNDARY commands. When zoomed in closely, boundary detection will fail. When zoomed so the contour 'looks' closed, the boundary is detectable.
Values between 0.0 and 500.0 are accepted.
| Type: |
Real |
| Saved in: |
Registry |
| Range: |
0 or greater |
| Default value: |
0.0 |
