HPMAXCONTOURPOINTS system variable
Maximum number of points on a hatch contour
Specifies the maximum number of points on a contour (outline) that a hatch entity can contain and still be rendered. Hatches do not render if the number of points exceeds the specified value. Values between 0 and 10000000 are accepted. The default value of this variable is 100000. Setting to 0 disables the check, i.e. variable is not used.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 10000000 |
| Default value: |
100000 |
