HPMAXCONTOURPOINTS system variable
Maximum number of points on a hatch contour
Controls the maximum number of points on a contour (outline) that a hatch entity can contain and still render.
Values between 0 and 10,000,000 are accepted.
Hatches do not render if the number of points exceeds the specified value.
Setting to 0 disables the check, meaning the variable is not used.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
0 to 10000000
Default value:
100000
