IFCEXPORTIDSPROPERTIESONLY system variable
Export IDS Properties Only
When an IDS-XML file has been imported, this setting controls whether only the properties required by the IDS file should be exported to the IFC file or all properties should be exported.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Default value: |
Off |
| Possible values: |
Off (0): Export all properties On (1): Export only the properties required by the IDS |
