IFCEXPORTSUBTRACTOPENINGS system variable
Subtracts the openings from the host geometry before export
Use this to increase the reliability of the geometry when opening in another software (it avoids relying on the boolean operations of the target software).
It will make editing the model in the target software more difficult.
Note: This behavior is the default for IFC4 Reference View file export.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: | 0 |
