IFCEXPORTTESSELATION system variable
Level of tessellation
Controls the level of tessellation of exported geometry. When the Current faceting option is chosen, no regeneration is required, the faceting as set by FacetRes or Modeler Properties is used. Choosing the Low, Medium, or High options causes corresponding regeneration of facets, which takes longer.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 3 |
| Default value: | 0 |
| Possible values: |
0: Current 1: Low 2: Medium 3: High |
