IFCIMPORTPROJECTSTRUCTUREASXREFS system variable
Import IFC project structure as XRefs
Imports IFC project structure as XRefs.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Range: |
0 to 1 |
| Default value: | 0 |
Note: When IFCIMPORTPROJECTSTRUCTUREASXREFS system variable is ON (1), an IFC file cannot be opened with drag and drop in a saved drawing, but the IMPORT command should be used. A warning message is displayed.
