IFCIMPORTUSESUBDMESH system variable
Import IFC meshes as subdivision meshes
Imports IFC meshes as subdivision meshes. If off, uses Polyface meshes to import meshes from IFC. A polyface mesh has a limitation of 32767 faces or vertices, a subdivision has no limitation.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: | 0 |
