IMPORTACISWITHBRICSCAD system variable
Import ACIS using built-in importer
Imports ACIS files with embedded routines, even if the Communicator is installed.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: | 0 |
