IMPORTCOLORS system variable
Translate colors
Controls how colors are converted during import.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 2 |
| Default value: |
1 |
| Possible options: |
0: To RGB 1: To RGB, if there is no matching palette index 2: To nearest palette index |
- If 0: all entity colors will be converted to RGB, regardless of the current palette.
- If 1: if the entity color is found in the palette, the entity gets an index color. Otherwise, it is given a true color.
- If 2: for any true color of the imported entity, the nearest match is searched in the palette and this index color is assigned to the entity.
