IMPORTCOLORS system variable
Translate colors
Defines color conversion on import.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 2 |
| Default value: |
1 |
| Possible values: | 0: To RGB: All entity colors will be converted to RGB, regardless of the current palette. 1: To RGB if no matching palette index: If the entity color is found in the palette, the entity gets an index color. Otherwise, it is given a true color. 2: To nearest palette index: For any true color of the imported entity, the nearest match is searched in the palette and this index color is assigned to the entity. |
