IMPORTCREOCONFIGURATION system variable
Import configuration
Sets the name of the configuration to import. If no configuration name is specified, then the part's default configuration is imported.
Note: A named configuration sets a collection of body entities in a part that can be imported as a group while suppressing the import of other body entities.
BricsCAD only
Type: |
String |
Saved in: |
Registry |
