IMPORTHIDDENPARTS system variable
Hidden parts
Controls how hidden parts are imported.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 2 |
| Default value: |
0 |
| Possible options: |
0: Import and hide 1: Import and set visible 2: Do not import |
- If 0: all entities are imported; invisible entities are hidden. Note that currently there are no user tools to make these hidden entities visible again.
- If 1: all entities are imported and visible, regardless of the visibility in the source file.
- If 2: hidden entities in the source file are not imported.
