IMPORTHIDDENPARTS system variable
Hidden parts
Controls how hidden parts are imported.
Type:
Short
Saved in:
Registry
Range:
0 to 2
Default value:
0
Possible values:
0: Import and hide
1: Import and set visible
2: Do not import
  • If 0: all entities are imported; invisible entities are hidden. Note that currently there are no user tools to make these hidden entities visible again.
  • If 1: all entities are imported and visible, regardless of the visibility in the source file.
  • If 2: hidden entities in the source file are not imported.
