IMPORTREPAIR system variable
Repair model on import
Automatically runs the DMAUDITALL command on imported models.
3D geometry is analyzed and problems are fixed automatically, in order to improve the quality of the imported geometry. Geometry modeled in CAD systems which use a kernel different from ACIS, often needs to be healed because of possible flaws.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
Off |
| Possible values: |
Off (0): Do not repair model on import On (1): Repair model on import |
