IMPORTSIMPLIFY system variable
Perform simplification
Enables automatic DMSIMPLIFY operation on imported model:
- Convert imported splines into canonical surfaces.
- Simplify topology (remove imprinted edges) if possible.
Note: Also check the IMPORTIGESSIMPLIFY setting, which can set an
override for the IGES file format.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: | 0 |
