IMPORTSOLIDWORKSSEARCHPATHSPREFERENCE system variable
Search paths preference
Controls the priority order for search paths during a Solid Works import.
Note: This option is taken into account only when import in background is enabled (COMMUNICATORBACKGROUNDMODE system variable is ON).
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
1 to 3 |
| Default value: |
1 |
| Possible options: |
1: Sub-folders first 2: Root folder only 3: Root folder first |
