IMPORTSTITCH system variable
Perform stitching
Enables automatic DMSTITCH operation on imported model.
In some cases, imported geometry represents solid geometry as a set of separate
surfaces. Use the DMSTITCH command to work with solid operations on the imported
geometry . If IMPORTSTITCH is set to ON, the DMSTITCH command is executed
automatically when the geometry is imported.
Note:
- Stitch operations are time-consuming when importing large files.
- Check the IMPORTIGESSTITCH setting, which can set an override for the IGES file format.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: | 0 |
