IMPORTSTITCH system variable
Perform stitching
Automatically runs the DMSTITCH command on imported models. See the IMPORTIGESSTITCH system variable.
In some cases, imported geometry represents solid geometry as a set of separate surfaces. Use the DMSTITCH command to work with solid operations on the imported geometry. If IMPORTSTITCH is set to ON, the DMSTITCH command is executed automatically when the geometry is imported.
Note:
  • Stitch operations are time-consuming when importing large files.
  • Check the IMPORTIGESSTITCH setting, which can set an override for the IGES file format.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value: 0
Possible values:
Off (0)
On (1)
