INSBASE system variable
Insertion base point
The drawing's insertion point, used when the drawing is inserted into other drawings as a block. Set by the BASE command, and expressed as a UCS coordinate for the current space.
| Type: |
3D point |
| Saved in: | Drawing |
| Default value: |
0,0,0 |
