INSUNITSSCALING system variable
Insertion units scaling
Controls how the INSUNITS system variable is applied when entities are inserted, imported or pasted.
BricsCAD only
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 3 |
| Default value: |
1 |
| Possible options: |
0: Use the INSUNITSDEFSOURCE system variable for scaling. 1: Scale with the INSUNITS system variable. 2: Use paper size unit instead of INSUNITS in paper space. |
When inserting or attaching Xrefs, Blocks or images the inserted content is scaled with respect to the value of INSUNITS in the target and source drawing.
- If INSUNITS in the source drawing is Unspecified, INSUNITSDEFSOURCE is used instead.
- If INSUNITS in the target drawing is Unspecified, INSUNITSDEFTARGET is used instead.
