INSUNITSSCALING system variable
Insertion units scaling
Controls how the INSUNITS system variable is applied when entities are inserted, imported or pasted.
BricsCAD only
| Type: | Short |
| Saved in: | Registry |
| Range: | 0 to 3 |
| Default value: | 1 |
| Possible values: | 1: Scale with the INSUNITS system variable, if inactive, uses the INSUNITSDEFSOURCE system variable 2: Use paper size unit instead of INSUNITS in paper space. |
When inserting or attaching Xrefs, Blocks or images the inserted content is scaled with respect to the value of INSUNITS in the target and source drawing.
- If INSUNITS in the source drawing is Unspecified, INSUNITSDEFSOURCE is used instead.
- If INSUNITS in the target drawing is Unspecified, INSUNITSDEFTARGET is used instead.
