INSUNITSSCALING system variable
Insertion units scaling
Controls how the INSUNITS system variable is applied when entities are inserted, imported or pasted.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
0 to 3
Default value:
1
Possible options:
0: Use the INSUNITSDEFSOURCE system variable for scaling.
1: Scale with the INSUNITS system variable.
2: Use paper size unit instead of INSUNITS in paper space.
When inserting or attaching Xrefs, Blocks or images the inserted content is scaled with respect to the value of INSUNITS in the target and source drawing.
  • If INSUNITS in the source drawing is Unspecified, INSUNITSDEFSOURCE is used instead.
  • If INSUNITS in the target drawing is Unspecified, INSUNITSDEFTARGET is used instead.
