INTERFERENCELEVEL system variable
Interference Check Level
Controls the interference check between details, copied details and/or the rest of the model.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 3 |
| Default value: | 0 |
| Possible options: |
0: No interference checking 1: Check overlap of detail volumes 2: Full interference check, ignore background spatial elements 3: Full interference checking |
