ISAVEBAK system variable
Incremental save backup
Specifies the creation of a backup file (BAK). Improves the speed of incremental saves if switched off, especially for large drawings.
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | On |
| Possible values: |
Off (0): Don’t create BAK file On (1): Create BAK file |
