LAYERPMODE system variable
Layer previous mode
Tracks layer settings modification and enables the LAYERP command.
Type: | Boolean |
Saved in: | Registry |
Range: | On |
Possible values: |
Off (0): Doesn’t allow tracking of layer settings modification and enables LAYERP command On (1): Allows tracking of layer settings modification and enables LAYERP command |
