LAYERPMODE system variable
Layer previous mode
Tracks layer settings modification and enables the LAYERP command.
| Type: | Boolean |
| Saved in: | Registry |
| Range: | On |
| Possible values: |
Off (0): Doesn’t allow tracking of layer settings modification and enables LAYERP command On (1): Allows tracking of layer settings modification and enables LAYERP command |
