LEGACYCODESEARCH system variable
Legacy code search mode (Read Only)
Enables unsafe search for executable code in drawing folders.
| Type: | Boolean |
| Saved in: | Not saved |
| Default value: | Off |
| Possible values: |
Off (0): Disable unsafe searching for executable code On (1): Enable unsafe searching for executable code |
