LENGTHUNITS system variable
Length units
Controls a list of units used to display lengths, if length properties are formatted with the PROPUNITS system variable. The string contains a space-separated list of unit abbreviations.
BricsCAD only
| Type: |
String |
| Saved in: |
Registry |
| Default value: |
"in ft mi µm mm cm m km" |
