LICFLAGS system variable
Licensed components (Read Only)
Controls if certain components are licensed or not. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
| Type: | Short |
| Saved in: | Not saved |
| Range: |
0 to 7 |
| Default value: |
0 |
| Possible options: |
0: No components licensed 1: VBA is licensed 2: Acis editing is licensed 4: Pro |
