LIMMAX system variable
Limits maximum
The upper-right corner of the drawing limits, expressed in world coordinates.
Type:
2D point
Saved in:
Drawing
Default value:
12, 9
Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 420, 297.
