LOADMECHANICAL2D system variable
Mechanical 2D Editor
Controls if Mechanical 2D enablers can load.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Loading of Mechanical 2D enablers is not permitted On (1): Loading of Mechanical 2D enablers is permitted |
Note: Changing the value of this variable will take effect after restarting the application.
