LOCALROOTPREFIX system variable
Local root prefix (Read Only)
The path of the folder, where local files for the current user, such as templates, were installed.
The Template and Textures folders are in this location, and you can add any customizable files that you do not want to roam on the network. See ROAMABLEROOTPREFIX for the location of the roamable files.
| Type: |
String Standard |
| Saved in: | Registry |
