LOFTMAG1 system variable
Loft magnitude 1
Sets the relative distance of the surface from the cross section in the direction of the LOFTANG1 system variable, before the surface starts to bend towards the next section. Works only if the LOFTNORMALS system variable is set to Surface uses draft angle and magnitude.
| Type: | Real |
| Saved in: | Drawing |
| Default value: |
0.0 |
