LOFTNORMALS system variable
Loft normals
Controls the behavior of surfaces and solids created with the LOFT command as they pass through a cross section.
Type:
Short
Saved in:
Drawing
Range:
0 to 6
Default value:
1
Possible options:
0: Ruled surface
1: Smooth surface
2: Surface is perpendicular to the first cross section
3: Surface is perpendicular to the last cross section
4: Surface is perpendicular to the first and last cross sections
5: Surface is perpendicular to all cross sections
6: Surface uses draft angle and magnitude
