LOOKFROMDIRECTIONMODE system variable
LookFrom direction mode
Controls how many view directions can be selected in isometric mode.
  • Windows and Linux: hold the Ctrl key to switch from top to down directions.
  • macOS: hold the Cmd key to switch from top to down directions.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
0 to 3
Default value:
1
Possible options:
0: Orthogonal only (6 directions)
1: No flat view at corners (14 directions)
2: 4 top/down corners(18 directions)
3: 8 top/down corners(26 directions)
