LOOKFROMDIRECTIONMODE system variable
LookFrom direction mode
Controls how many view directions can be selected in isometric mode.
- Windows and Linux: hold the Ctrl key to switch from top to down directions.
- macOS: hold the Cmd key to switch from top to down directions.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: |
0 to 3 |
| Default value: |
1 |
| Possible options: |
0: Orthogonal only (6 directions) 1: No flat view at corners (14 directions) 2: 4 top/down corners(18 directions) 3: 8 top/down corners(26 directions) |
