LWDEFAULT system variable
Default lineweight
Controls the default lineweight, in hundredths of millimeters.
| Type: |
                            Short  |
| Saved in: |
                            Registry  |
| Range: |
                            0 to 211  |
| Default value: |
                            25  |
| Possible values: |
                            -3: Default (defined by LWDEFAULT) -2: ByBlock -1: ByLayer 0 - 211: Lineweight value in hundredths of millimeters  |
