MASSPREC system variable
Mass precision
Controls the number of decimal places displayed for masses, if mass properties are formatted with the PROPUNITS system variable.
Note: If negative, LUPREC (Linear Unit Precision) is used.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
-1 to 8
Default value:
-1
Possible options:
-1: Use LUPREC
0: 0
1: 0.0
2: 0.00
3: 0.000
4: 0.0000
5: 0.00000
6: 0.000000
7: 0.0000000
8: 0.00000000
