MASSPROPACCURACY system variable
Mass properties calculation relative accuracy
Controls the accuracy used for mass properties calculations. This accuracy is relative. For a value of 3 the calculated values may deviate up to 0.1% from the actual value, for 12 it is 1.e-10%. For value of 2 the deviation may exceptionally exceed 1% and we assume a margin of 2%.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Default value: |
2 |
| Possible options: |
2: 2% accuracy 3: 0.1% accuracy 4: 0.01% accuracy 5: 0.001% accuracy 6: 1.e-4% accuracy 7: 1.e-5% accuracy 8: 1.e-6% accuracy 9: 1.e-7% accuracy 10: 1.e-8% accuracy 11: 1.e-9% accuracy 12: 1.e-10% accuracy |
