MASSUNITS system variable
Mass units
Controls the units used to display mass, if mass properties are formatted with the PROPUNITS system variable. If empty, all masses are displayed without units.
The MASSUNITS setting affects the mass values only. Other mass properties such as density or moments of inertia are formatted in SI units for the metric system and in imperial units for the imperial system, regardless of the MASSUNITS setting.
The string contains a space-separated list of unit abbreviations.
BricsCAD only
| Type: |
String |
| Saved in: |
Registry |
| Default value: |
oz lb st mg g kg t |
