MASSUNITS system variable
Mass units
Specifies a list of units used for displaying mass when the mass bit of PROPUNITS is on. If empty, all masses are displayed without units.
The MASSUNITS setting affects the mass values only. Other mass properties such as density or moments of inertia are formatted in SI units for the metric system and in imperial units for the imperial system, regardless of the MASSUNITS setting.
BricsCAD only
| Type: |
String |
| Saved in: |
Registry |
| Default value: |
oz lb st mg g kg t |
