MAXTHREADS system variable
Maximum number of threads
Controls the maximum number of threads used to display and load drawings and point cloud operations. See also the MTFLAGS system variable.
Values between 0 and 16 are accepted. A value of zero means automatically use the optimal number of threads.
BricsCAD only
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 16 |
| Default value: |
0 |
