MECHANICALBLOCKS system variable
Mechanical blocks
Enables or disables mechanical blocks as an alternative to mechanical components.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
On
Off (0): Disables mechanical blocks
On (1): Enables mechanical blocks
Related commands
  • BMFORM command
  • BMMECH command
  • BMNEW command
  • BMUNMECH command
