MECHANICALBROWSERSETTINGS system variable
Mechanical browser options
Sets the default mechanical browser options.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 511 |
| Default value: |
179 |
| Possible options: |
1: Expressions of constraints 2: Block parameters 4: Expressions of block parameters 8: Nested mechanical blocks of standard part 16: Arrays 32: Block and External References 64: Keep values list order 128: Asynchronous properties load 256: Expose all solids |
